Водометный катер Била Рассела
Сообщение bottomdweller » 06 дек 2011, 04:14
this 1 is ecotec 252 hp super charged with a scott 752 and will run top speed of 51 miles per hour on the river and get on step in 10 feet and carry very big load
bottomdweller
Сообщение bottomdweller » 06 дек 2011, 04:18
if 1 of you men can reply to my post and let me know if the translation in fine and you understand it or if it is hard to understand
bottomdweller
Сообщение bottomdweller » 06 дек 2011, 05:17
this 1 is 16 feet with a top speed of 36 mph. it has a yamaha 2 stroke 60hp engine with a 148mm water cannon
i took 1 like this to alaska to hunt caribou and we hunted 4 guys in the boat 30 miles up river
i took 2 trips to get all the men and hunting gear and food and extra fuel up river
we hunted for 8 days and only burned 38 gallon of fuel .and this boat is 900 lbs
bottomdweller
Сообщение Fuso » 06 дек 2011, 06:32
sufficiently clear. I use online translator but the meaning is clear
Fuso
Сообщение bottomdweller » 06 дек 2011, 06:49
i am glad to hear that you understand my words with the translator
when i use the translator to read what is in russia i think i am not getting all the works right that you have wrote in the post
i think that some works that are in russian do not translate very well .
bottomdweller
Сообщение Ajak » 06 дек 2011, 07:28
bottomdweller писал(а):if 1 of you men can reply to my post and let me know if the translation in fine and you understand it or if it is hard to understand
Bill all perfectly understand you, keep writing the same way ! ;)
Tell me Bill, what the fuel consumption per hour at ECOTEC 175 and 252?
What engines did you use with water jets "Aqua Jet"?
What do you think productive water jets Flo \ Pro or 752 SWJ provided that uses the same engine and the boat?
Regards ...
Ajak
Сообщение bottomdweller » 06 дек 2011, 07:41
the aquajet - good for engines 80hp - 180 hp with the correct impeller we have impellers made for these that will work with this range of horse power
coggen good for engines 60- 210 hp and we have many good impellers for this water cannon in 3 and 4 blade impellers
scott 751 good engines from 100-200hp
scott 752 good for engines from 200-350hp
flo-pro good for 100-350hp and we have also used this flo-pro with a diesel 170hp
bottomdweller
Сообщение дядя Вася » 06 дек 2011, 08:44
Hi Bill
1. Why you don't us Outboardjet ?
2. What do you think about engine Weber 750 MPE with jet-pump?
(sorry my english ;)
Сообщение kormik » 06 дек 2011, 13:35
Человек хочет пару своих лодок в россию продать
Думает на общалке тематической рекламируется
Не знает бедолага, куда попал :lol:
kormik
Сообщение Ajak » 06 дек 2011, 16:17
Он уже продал 2 катера в РФ( Якутск ), сейчас с дизелями делает туда-же. Он на "своей волне"ему хватает заказов как в US так и в CANAD-e .
Попал по приглашению на этот форум, т.к это касается его бизнеса и он хочет знать мнения о своих лодках , так же поделиться своим опытом, как он делает на всех профильных форумах от Анкориджа до Крейсчета ....
Ajak
